I have installed xampp and mysql is not geting start showing: mysql_error.log, its details are given below
Thread began 5/31/2017 11:17 am by anonymous | Last modified 5/31/2017 6:00 pm by Ray Borduin | 3985 views | 1 replies |
anonymous
2015-11-10 15:26:56 10fc InnoDB: Warning: Using innodb_additional_mem_pool_size is DEPRECATED. This option may be removed in future releases, together with the option innodb_use_sys_malloc and with the InnoDB's internal memory allocator.
2015-11-10 15:26:56 4348 [Note] InnoDB: Using mutexes to ref count buffer pool pages
2015-11-10 15:26:56 4348 [Note] InnoDB: The InnoDB memory heap is disabled
2015-11-10 15:26:56 4348 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions
2015-11-10 15:26:56 4348 [Note] InnoDB: Memory barrier is not used
2015-11-10 15:26:56 4348 [Note] InnoDB: Compressed tables use zlib 1.2.3
2015-11-10 15:26:56 4348 [Note] InnoDB: Not using CPU crc32 instructions
2015-11-10 15:26:56 4348 [Note] InnoDB: Initializing buffer pool, size = 16.0M
2015-11-10 15:26:56 4348 [Note] InnoDB: Completed initialization of buffer pool
2015-11-10 15:26:56 4348 [Note] InnoDB: Highest supported file format is Barracuda.
2015-11-10 15:26:57 4348 [Note] InnoDB: 128 rollback segment(s) are active.
2015-11-10 15:26:57 4348 [Note] InnoDB: Waiting for purge to start
2015-11-10 15:26:57 4348 [Note] InnoDB: Percona XtraDB (http://www.percona.com) 5.6.26-74.0 started; log sequence number 1835027
2015-11-10 15:26:57 6140 [Note] InnoDB: Dumping buffer pool(s) not yet started
2015-11-10 15:26:57 4348 [Note] Plugin 'FEEDBACK' is disabled.
2015-11-10 15:26:57 4348 [Note] Server socket created on IP: '::'.
2015-11-10 15:26:57 4348 [Note] Event Scheduler: Loaded 0 events
2015-11-10 15:26:57 4348 [Note] C:\xampp\mysql\bin\mysqld.exe: ready for connections.
Version: '10.1.8-MariaDB' socket: '' port: 3306 mariadb.org binary distribution
2015-11-10 15:27:11 5152 [Note] C:\xampp\mysql\bin\mysqld.exe: Normal shutdown
2015-11-10 15:27:11 5152 [Note] Event Scheduler: Purging the queue. 0 events
2015-11-10 15:27:11 5732 [Note] InnoDB: FTS optimize thread exiting.
2015-11-10 15:27:11 5152 [Note] InnoDB: Starting shutdown...
2015-11-10 15:27:13 5152 [Note] InnoDB: Shutdown completed; log sequence number 1835037
2015-11-10 15:27:13 5152 [Note] C:\xampp\mysql\bin\mysqld.exe: Shutdown complete
2017-06-01 06:07:01 11a0 InnoDB: Warning: Using innodb_additional_mem_pool_size is DEPRECATED. This option may be removed in future releases, together with the option innodb_use_sys_malloc and with the InnoDB's internal memory allocator.
2017-06-01 6:07:01 4512 [Note] InnoDB: innodb_empty_free_list_algorithm has been changed to legacy because of small buffer pool size. In order to use backoff, increase buffer pool at least up to 20MB.
2017-06-01 6:07:01 4512 [Note] InnoDB: Using mutexes to ref count buffer pool pages
2017-06-01 6:07:01 4512 [Note] InnoDB: The InnoDB memory heap is disabled
2017-06-01 6:07:01 4512 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions
2017-06-01 6:07:01 4512 [Note] InnoDB: _mm_lfence() and _mm_sfence() are used for memory barrier
2017-06-01 6:07:01 4512 [Note] InnoDB: Compressed tables use zlib 1.2.3
2017-06-01 6:07:01 4512 [Note] InnoDB: Using generic crc32 instructions
2017-06-01 6:07:01 4512 [Note] InnoDB: Initializing buffer pool, size = 16.0M
2017-06-01 6:07:01 4512 [Note] InnoDB: Completed initialization of buffer pool
2017-06-01 6:07:01 4512 [Note] InnoDB: Highest supported file format is Barracuda.
2017-06-01 6:07:05 4512 [Note] InnoDB: 128 rollback segment(s) are active.
2017-06-01 6:07:05 4512 [Note] InnoDB: Waiting for purge to start
2017-06-01 6:07:05 4512 [Note] InnoDB: Percona XtraDB (http://www.percona.com) 5.6.34-79.1 started; log sequence number 1835037
2017-06-01 6:07:05 10064 [Note] InnoDB: Dumping buffer pool(s) not yet started
2017-06-01 6:07:05 4512 [Note] Plugin 'FEEDBACK' is disabled.
2017-06-01 6:07:05 4512 [Note] Server socket created on IP: '::'.
2017-06-01 6:07:05 4512 [ERROR] Can't start server: Bind on TCP/IP port. Got error: 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted.
2017-06-01 6:07:05 4512 [ERROR] Do you already have another mysqld server running on port: 3306 ?
2017-06-01 6:07:05 4512 [ERROR] Aborting
2017-06-01 06:07:14 2eb4 InnoDB: Warning: Using innodb_additional_mem_pool_size is DEPRECATED. This option may be removed in future releases, together with the option innodb_use_sys_malloc and with the InnoDB's internal memory allocator.
2017-06-01 6:07:14 11956 [Note] InnoDB: innodb_empty_free_list_algorithm has been changed to legacy because of small buffer pool size. In order to use backoff, increase buffer pool at least up to 20MB.
2017-06-01 6:07:15 11956 [Note] InnoDB: Using mutexes to ref count buffer pool pages
2017-06-01 6:07:15 11956 [Note] InnoDB: The InnoDB memory heap is disabled
2017-06-01 6:07:15 11956 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions
2017-06-01 6:07:15 11956 [Note] InnoDB: _mm_lfence() and _mm_sfence() are used for memory barrier
2017-06-01 6:07:15 11956 [Note] InnoDB: Compressed tables use zlib 1.2.3
2017-06-01 6:07:15 11956 [Note] InnoDB: Using generic crc32 instructions
2017-06-01 6:07:15 11956 [Note] InnoDB: Initializing buffer pool, size = 16.0M
2017-06-01 6:07:15 11956 [Note] InnoDB: Completed initialization of buffer pool
2017-06-01 6:07:15 11956 [Note] InnoDB: Highest supported file format is Barracuda.
2017-06-01 6:07:16 11956 [Note] InnoDB: 128 rollback segment(s) are active.
2017-06-01 6:07:16 11956 [Note] InnoDB: Waiting for purge to start
2017-06-01 6:07:16 11956 [Note] InnoDB: Percona XtraDB (http://www.percona.com) 5.6.34-79.1 started; log sequence number 1835541
2017-06-01 6:07:16 11792 [Note] InnoDB: Dumping buffer pool(s) not yet started
2017-06-01 6:07:16 11956 [Note] Plugin 'FEEDBACK' is disabled.
2017-06-01 6:07:16 11956 [Note] Server socket created on IP: '::'.
2017-06-01 6:07:16 11956 [ERROR] Can't start server: Bind on TCP/IP port. Got error: 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted.
2017-06-01 6:07:16 11956 [ERROR] Do you already have another mysqld server running on port: 3306 ?
2017-06-01 6:07:16 11956 [ERROR] Aborting
2017-06-01 06:07:23 138c InnoDB: Warning: Using innodb_additional_mem_pool_size is DEPRECATED. This option may be removed in future releases, together with the option innodb_use_sys_malloc and with the InnoDB's internal memory allocator.
2017-06-01 6:07:23 5004 [Note] InnoDB: innodb_empty_free_list_algorithm has been changed to legacy because of small buffer pool size. In order to use backoff, increase buffer pool at least up to 20MB.
2017-06-01 6:07:23 5004 [Note] InnoDB: Using mutexes to ref count buffer pool pages
2017-06-01 6:07:23 5004 [Note] InnoDB: The InnoDB memory heap is disabled
2017-06-01 6:07:23 5004 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions
2017-06-01 6:07:23 5004 [Note] InnoDB: _mm_lfence() and _mm_sfence() are used for memory barrier
2017-06-01 6:07:23 5004 [Note] InnoDB: Compressed tables use zlib 1.2.3
2017-06-01 6:07:23 5004 [Note] InnoDB: Using generic crc32 instructions
2017-06-01 6:07:23 5004 [Note] InnoDB: Initializing buffer pool, size = 16.0M
2017-06-01 6:07:23 5004 [Note] InnoDB: Completed initialization of buffer pool
2017-06-01 6:07:23 5004 [Note] InnoDB: Highest supported file format is Barracuda.
2017-06-01 6:07:24 5004 [Note] InnoDB: 128 rollback segment(s) are active.
2017-06-01 6:07:24 5004 [Note] InnoDB: Waiting for purge to start
2017-06-01 6:07:24 5004 [Note] InnoDB: Percona XtraDB (http://www.percona.com) 5.6.34-79.1 started; log sequence number 1835551
2017-06-01 6:07:24 9740 [Note] InnoDB: Dumping buffer pool(s) not yet started
2017-06-01 6:07:24 5004 [Note] Plugin 'FEEDBACK' is disabled.
2017-06-01 6:07:24 5004 [Note] Server socket created on IP: '::'.
2017-06-01 6:07:24 5004 [ERROR] Can't start server: Bind on TCP/IP port. Got error: 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted.
2017-06-01 6:07:24 5004 [ERROR] Do you already have another mysqld server running on port: 3306 ?
2017-06-01 6:07:24 5004 [ERROR] Aborting
2017-06-01 06:08:28 25f0 InnoDB: Warning: Using innodb_additional_mem_pool_size is DEPRECATED. This option may be removed in future releases, together with the option innodb_use_sys_malloc and with the InnoDB's internal memory allocator.
2017-06-01 6:08:28 9712 [Note] InnoDB: innodb_empty_free_list_algorithm has been changed to legacy because of small buffer pool size. In order to use backoff, increase buffer pool at least up to 20MB.
2017-06-01 6:08:28 9712 [Note] InnoDB: Using mutexes to ref count buffer pool pages
2017-06-01 6:08:28 9712 [Note] InnoDB: The InnoDB memory heap is disabled
2017-06-01 6:08:28 9712 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions
2017-06-01 6:08:28 9712 [Note] InnoDB: _mm_lfence() and _mm_sfence() are used for memory barrier
2017-06-01 6:08:28 9712 [Note] InnoDB: Compressed tables use zlib 1.2.3
2017-06-01 6:08:28 9712 [Note] InnoDB: Using generic crc32 instructions
2017-06-01 6:08:28 9712 [Note] InnoDB: Initializing buffer pool, size = 16.0M
2017-06-01 6:08:28 9712 [Note] InnoDB: Completed initialization of buffer pool
2017-06-01 6:08:28 9712 [Note] InnoDB: Highest supported file format is Barracuda.
2017-06-01 6:08:29 9712 [Note] InnoDB: 128 rollback segment(s) are active.
2017-06-01 6:08:29 9712 [Note] InnoDB: Waiting for purge to start
2017-06-01 6:08:29 9712 [Note] InnoDB: Percona XtraDB (http://www.percona.com) 5.6.34-79.1 started; log sequence number 1835561
2017-06-01 6:08:29 8424 [Note] InnoDB: Dumping buffer pool(s) not yet started
2017-06-01 6:08:29 9712 [Note] Plugin 'FEEDBACK' is disabled.
2017-06-01 6:08:29 9712 [Note] Server socket created on IP: '::'.
2017-06-01 6:08:29 9712 [ERROR] Can't start server: Bind on TCP/IP port. Got error: 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted.
2017-06-01 6:08:29 9712 [ERROR] Do you already have another mysqld server running on port: 3306 ?
2017-06-01 6:08:29 9712 [ERROR] Aborting
Your dump has the same set of errors repeated. The full list is:
I'd go through it line by line and google what each means.
I'm not a server configuration expert, so I can't really make heads or tails of this. I'd find a xampp forum to post this to.
