Paypal Subscribe problems....
Thread begun 5/25/2017 5:33 am by codamedia | Last modified 5/25/2017 3:03 pm by Ray Borduin | 1217 views | 3 replies |
codamedia
I am attempting to setup a PayPal subscribe button using the free tools, and have a few questions.
On step 3 of 5, the radio button is not working for choosing to stop after "x" amount of payments. Clicking on the radio button activates the # of payments (ie: I can choose the number of payments) but the radio button is not changing to indicate I have actually made that choice and that it is generating the code properly because of this.
I appear to be running the latest extensions, and tried in both CS4 and CS6.... same issue in both.
Also - is there a reference to this POST style API. I cannot find it anywhere on the PayPal site, just restful and soap API's. I would like to know what the post values actually stand for such as "a3, p3, t3, mrb, pal,srt, sra, etc...".
Thanks....
The list of paypal standard variables can be found here:
https://developer.paypal.com/docs/classic/paypal-payments-standard/integration-guide/Appx_websitestandard_htmlvariables/
I'm looking into the radio button issue. I'm going to have to get a new build out to address it.
It appears that even though the radio isn't correct in the UI, the resulting code is correct. That should set the value of the hidden field "srt" and set it to the number selected in the list.
codamedia
Thanks for the link Ray....
Yes - the generated code seems to be correct when running tests. It's the first time I've used this so I was concerned when the radio button didn't actually select.
I've updated the extension so if you reinstall it the radios will look correct. But really it is easy enough to ignore since it works properly as it is.
