plugin question
hey Ray
Am trying to include a plugin of an update page where it shows a specific update content (eg homepage_header.php?HomepageHeaderID=1) but cannot see how to get this to work?
Cheers
Jamie
hey Ray
Cheers
Jamie
If you want a URL parameter to be available in the plugin you can set it manually in the php before calling the plugin like:
$_GET['HomepageHeaderID'] = 1;
sorry Ray, I dont follow how to do that :S
If you pass the url parameter into the page where you have the plugin it will be available automatically. However if you want to pass a url parameter to the plugin page specifically you can set it directly in the code above with code like this:
Then if you have the plugin referenced with "homepage_header.php" it will work as if it was: homepage_header.php?HomepageHeaderID=1
penny has finally dropped on this one - understand now and got it working. thanks, Jamie
