status of query
Is there a way i can get a status of if the query was successful or not?
Id like to know if the update or delete was performed successful.
The status is part of the object, so you could access it. To see the whole object you can use var_dump($queryObjName); that will show you all of values from the query object. Hypothetically once you have it working it should always be successful.
