random record s
Thread began 5/01/2017 5:23 pm by software.current355386 | Last modified 5/01/2017 7:12 pm by Ray Borduin | 306 views | 1 replies |
random record s
trying to pick out random database records have got tuck can you hlp
have used thin the past but that involved randomly seleteding records from the wole database
STEP1 sleeted all record into array , sliced and shuffled array total rows is no of records in database
STEP2 Use the final array to print by record no
What i would like to do is filter the rects in STEP1 and repot on them
[DB_Random] => Array ( [0] => 9 [1] => 11 [2] => 5 [3] => 10 [4] => 6 [5] => 7 ) ) filtered record numbers
this should read
[DB_Random] => Array ( [0] => 9 [1] => 21 [2] =>25 [3] => 1 [4] => 86 [5] =>67 ) ) actual database record number required to be stored not the filtered record number
t1.php
You can just add this to the end of your recordset to return the values in a random order:
ORDER BY RAND()
