recordset syntax help needed
Thread began 4/21/2017 6:58 am by Brendan | Last modified 4/25/2017 10:19 am by Ray Borduin | 1099 views | 3 replies |
Brendan
I am trying to update some reports after adding a quantity component to a donation site. I basically need to find the quotient of 2 fields (detialPrice * detailQuantity) and then SUM those amounts for like entries. Here is what I tried, and I'm getting an error that the column "pplTotal" is unrecognized.
SELECT (orderdetails.DetailPrice * orderdetails.DetailQuantity) AS pplTotal, DetailID, DetailSchool, DetailStudentF, DetailStudentL, sum(pplTotal) AS FRtotal
That column doesn't exist yet, you would have to use: SUM(orderdetails.DetailPrice * orderdetails.DetailQuantity)
Brendan
it isn't working quite right. The recordset above is supposed to group entries by the students names, then return a total of all pledges made to them.
For example, if student John Smith has 2 entries in the database, one with price 50 quantity 1, and the other with price 5 quantity 10 - the result should be John Smith 100.
I assume this may be too much to do in one step, which is why I had originally tried to find the product of price and quantity, then sum the results of that operation.
SELECT (orderdetails.DetailPrice * orderdetails.DetailQuantity) AS pplTotal, DetailID, DetailSchool, DetailStudentF, DetailStudentL, sum(orderdetails.DetailPrice * orderdetails.DetailQuantity) AS FRtotal GROUP BY DetailStudentF, DetailStudentL
