HTML Encode- problem with feed validation
Thread began 4/21/2017 6:24 am by Nathon Jones Web Design | Last modified 4/24/2017 4:11 pm by Ray Borduin | 1627 views | 7 replies |
How do I add HTML Encode to data from a recordset so that it convert characters to the correct format?
<?php echo $row['newsTITLE']; ?>
....is not validating correctly when the title includes, for example, an ampersand.
Thank you.
NJ
<?php echo(htmlentities($row['newsTITLE'])); ?>
Thank you Ray.
If we have "£" in the database table field this renders as "&pound;" in the validator which, even with htmlentities, produces the parsing error. The data is submitted using a textarea form field so I'm not sure why it's not validating properly.
https://validator.w3.org/feed/check.cgi?url=http%3A%2F%2Fwww.gallowayfisheriestrust.org%2Frss-fisheries-trust-news.php
Any idea what could be causing this?
Much appreciated
NJ
It will allow you to use ampersands in your content if you escape it with a CDATA tag like:
<item> <![CDATA[ Smith & Wesson ]]> </item>
So...
<item><![CDATA[<?php echo(htmlentities($row['newsTITLE'])); ?>]]></item>
Will give that a try anyway. Thank you Ray.
NJ
That looks right.
It's now validating, but it's still finding a problem with &amp;
RSS feeds. Does anyone even use these any more?
Try using: htmlspecialchars()
instead of: htmlentities()
