Error on update page
Thread began 4/20/2017 7:51 am by iain331081 | Last modified 4/21/2017 8:57 am by Ray Borduin | 2507 views | 6 replies |
iain331081
Not sure what's up with this one, but getting an error 'Unknown column 'UserID' in 'where clause' when I try to save the update.
Probably something really obvious, but I haven't spotted it.
Have attached a copy of the page below.
Thanks for having a look.
Line 132 you have:
$WA_indexField = "UserID";
That must not be valid column name for the agents table.
iain331081
Thanks Ray - the page pulls through data from the agents and trade_users tables. Basically agents are the parent companies and trade_users are the contacts at the companies.
And this form is just updating the agent details. So sounds like I need to either change the query or add a second one for the update.
It threw me as it was fine for the page before doing the update.
That should be updated to the column name in the agents table that has the user id field value in it... or if that isn't unique it should be set to the unique field in the agents table and then the hidden form element WADAUpdateRecordID should be set to the correct associated value.
iain331081
Sorry Ray - think I posted the wrong version of the page I was looking at.
I have attached a revised version now - same link and login as before.
So it should be referencing the UserID of the tree_users table with the fields it should update.
This is giving me the error:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'WHERE `UserID`='7857'' at line 1
Not sure why, as its fine when the page loads before submitting the form?
You had added a column to the update "LastUpdatedBy" but that column didn't have a value in the values list nor did it exist in the database. I've removed it from line 134 and that appears to have fixed the problem.
iain331081
Thanks Ray - sorry I missed that.
