Pages suddenly do not work.
please see PM
I just tried and it seemed to work for me. What happens when you try? It might be a particular value for a particular field that is causing it to fail.
You have Beam and Beam_Measure as required fields in your validation but haven't filled in those fields in your test.
Thanks Ray
I deleted the row containing the beam boxes but the problem remained
I tried running a modified version of the page with all table rows deleted except manufacturer and validation text box and it still did not redirect to the next page.
I wondered if the Next Button is correct.
I cannot see where it directs to the next page, although the Next buttons in the other pages are similar.
Did you delete the validation row for the beam boxes? That would be rows 20 and 21. That is where the issue was.
I just looked and those rows are still on the site.
Seems to be working correctly on the remote host now Ray.
Thank you very much for all the help.
Fantastic!!
Regards
John
