Possible to use tables from two seperate MySQL databases to create an INNER JOIN?
I can connect to two different databases on one page, but is it possible to combine tables from each of those databases in order to create an INNER JOIN link?
NJ
NJ
It is possible if the two databases are on the same server. You would just have to refer to them as DatabaseName.TableName in your SELECT statement.
