If required fields are missing when submitted, files to be uploaded have to be entered again
This post has been deleted.
That is normal with file upload fields. If you use client side validation then it should catch most of the issues and it won't happen very often.
For security reasons you can't pre-populate an upload file field.
Ok. great thanks for the info.. It will be fine..
