Static Menu Item in Dynamic LIst
Thread began 3/17/2017 9:21 am by Mike Perry | Last modified 3/17/2017 11:53 am by Ray Borduin | 1592 views | 6 replies |
Mike Perry
My Dynamic List/Menu is not showing the statis menu itam in the select box when the page is loaded.
<select code below>
<div class="fullColumnGroup"><label for="leagueName" class="sublabel" >League Name:</label>
<select class="formMenufield_Medium" name="leagueName" id="leagueName" rel="<?php echo((isset($_GET["leagueName"])?$_GET["leagueName"]:"")); ?>" tabindex="1" title="Please enter a value.">
<option value="" <?php if (!(strcmp("", $row_WADAMenuleagueName['id']))) {echo "selected=\"selected\"";} ?>>Select a League</option>
do {
<option value="<?php echo $row_WADAMenuleagueName['id']?>"<?php if (!(strcmp($row_WADAMenuleagueName['id'], $row_WADAMenuleagueName['id']))) {echo "selected=\"selected\"";} ?>><?php echo $row_WADAMenuleagueName['leagueName']?></option>
} while ($row_WADAMenuleagueName = mysql_fetch_assoc($WADAMenuleagueName));
$rows = mysql_num_rows($WADAMenuleagueName);
if($rows > 0) {
mysql_data_seek($WADAMenuleagueName, 0);
$row_WADAMenuleagueName = mysql_fetch_assoc($WADAMenuleagueName);
</select>
The last last item in the recordset is the default selection instead of "Select a League".
Thanks,
Mike
You have this as your selected value code:
If you remove that it will select the first item instead.
Mike Perry
I had found that solution in a previous post and tried it -- no luck.
Here is my opening select code and the first option code:
<option value="">Select a League</option>
The last item in the dynamic array is still what shows as the default. .
It is the code in the repeated option that has to be updated. What do you have there?
Mike Perry
ETA: Okay -- changed it in the repeated section and it's good.
What do I need to change in the wizard inputting to keep that code from appearing?
Don't add anything in the "set selected value" field.
Mike Perry
Got it--
Thanks again, Ray!!
