Form Builder form won't send email
Thread began 3/08/2017 3:02 pm by tmcbinc99963 | Last modified 4/12/2017 3:24 pm by Ray Borduin | 1859 views | 17 replies |
tmcbinc99963
I created a Form Builder form for a 'contact us' page, then copied that form for a 'career opportunities' page. Some of the form elements were deleted, plus a WA dynamic checkbox was added with validation. I deleted the UE server behavior instance from the old page and added new: 'blank_2.php. I then opened the old UE 'blank' page, edited and saved as 'blank_2' for the new page.
The form won't submit. I deleted the checkbox with validation, thinking it could be a validation error, but still not sending. Also changed the trigger to the submit button name, but still nothing.
You have an odd server validation entry where you are validating a validated field:
$WAFV_Errors .= WAValidateRQ((ValidatedField("FindSalesRep","JobOps[]")) . "",false,3);
That line doesn't make sense and is likely the culprit. Try deleting that line (line 17)
tmcbinc99963
I've rebuilt the 'show if's' and removed the referenced code (from a checkbox I added, but removed), but still can't get the form to send.
Added 'show errors' code, but no errors.
The email is attempting to send. Have you checked spam filters? Do other emails from your site work? Do you have access to the email logs from your server?
I added a simple test email to a page called session.php and it doesn't seem to send either.
tmcbinc99963
Other forms on the site work. I contacted the host provider anyway and added the credentials for their mail server into the UE dialog box (also checked the box at bottom), but still no send. The other form, ContactUs.php didn't have the credentials, but still sent an email.
Thought it might also be the form page trying to send data with no bindings on the email page (blank_2), so I reworked the email page, but still no send.
I have a file upload button on the form page with no binding on the email page, but even if I don't attach a file, it still doesn't send.
Also, what binding should be used for the file attachment? The blank_2.php form bindings list doesn't show a binding for that.
I ended up getting the emails a few hours later when I did my tests. Are you sure it isn't working for you? It seemed to just be delayed.
tmcbinc99963
I sent the CareerOps.php form at 7 am this morning, but have received no emails as yet. The other forms on the site, ContactUs.php (built with Form Builder) and confirm.php (with eCart) is being received.
You had your trigger set to a "Validated Field" entry, which should only be used to repopulate form values after a failed validation.
You also had specified a mail server, where none was specified in the working email.
I corrected these issues and the email seems to send now.
tmcbinc99963
It seems both forms are using the same UE email settings file. When I uploaded the dependent files from the CareerOps.php page from the server, the UE email settings are the same for both forms. If I change them and upload, then the ContactUs.php page email file will change. As I mentioned in an earlier post, I 'saved as' my ContactUs.php page to create the CareerOps.php page, which could be causing the issue.
After I uploaded your corrected CareerOps.php files the UE interface has the ContactUs.php UE settings. I need to use a unique 'blank' email page for each one, but now the CareerOps.php page has picked up the ContactUs.php 'blank' page, rather than the 'blank_2' page I created for it.
You hadn't uploaded the blank2.php page... so I set it back to the blank.php page so I could test it. I also updated the settings which is why they appeared to be the same when you checked. Did you get the emails from yesterday that I tested? I did.
Also you had the FROM address set to an email address from a different domain that matched the TO address. The incoming email server would be able to see that it didn't actually send that email and could block it as spam. You should also use the same FROM address from the working email.
