Image upload browse server errors
Sending you a screen shot of the errors that show up. I have no idea where to start to fix this error. Can you assist?
Can I get ftp access and steps to reproduce? I can try changing the configuration settings to use a different type of database connection to see if that will fix it.
Sorry I also need a url to reproduce the problem and then I can take a look.
I just had to turn off STANDARDS errors. They don't effect the functionality of the page.
However I see that page isn't currently password protected. That is a big security hole. You should make sure someone can't access the file manager before they log in.
I ran the security assist > manage site access dropdown to secure this page, it did not work. I ran the "Secure Page" as well, no luck. It appears that my admin and super admin rules "no longer exist". I previously used data assist to build his patents pages and put a link to it in the top of the CMS page. Everything worked fine, pages secured. I read through the support area and found threads that said running the security wizard would restore the admin rules. I was not so fortunate, got frustrated and gave up. I know it needs to be fixed for security reasons, but I will have to deal with that after I get all his content moved into the CMS. Thanks for your help, I will contact you when I need help to secure this page.
Something went wonky with the html editor. I moved all the content into the CMS and everything was working great. When I checked it today to prepare my instruction for the flient it is not.
Admin user login fails and I have to log-in as super admin. Hitting the edit button on any of the content just takes you back to the index page. History and log out do not work either. The part I built with data assist for his patents database works great still. I have a meeting with the client to train their person on the CMS Friday at 4:30 MST
CAN YOU HELP ME FIX IT!!!!
P.S. I did re-upload the HTML EDITOR directory by that did not help. (ALSO EMAIL ME WITH ALL REPLIES BOX ABOVE IS NOT SENDING ME AN EMAIL)
As I look at this this morning I'm thinking it is a rules or session variable can't track it down.
The session wasn't starting properly on that page. I've resolved that issue. Let me know if you run into any more problems.
THANKS RAY. Do I need to download files to my local drive so I don't accidentally hose it again? I will check the file dates and download the most current. YOU ARE A LIFESAVER, AS ALWAYS.
