Error with Image Resizer
Thread begun 3/04/2017 12:23 pm by Daryl | Last modified 3/07/2017 3:16 pm by Ray Borduin | 2227 views | 7 replies |
DarylBeta Tester
I have had a site running for quite a few years with no problems other than when php versions have been changed.
Tonight I had an issue where googleapis have stopped jquery 1.8.2 being used and as such have had to link directly to the jquery site version in order to allow images to be uploaded.
I have now noticed that when an image is uploaded I get the following error with image resizer
Notice:
: Use of undefined constant resize_smaller - assumed 'resize_smaller' in
/home/nikisms/public_html/webassist/caching/CachedResize_Image.php
on line 164
Any ideas?
Please attach a copy of the file mentioned in the error and I'll take a look.
DarylBeta Tester
I have attached the file requested, thanks Ray
Can I see your page: CachedResize_Image.php that has the error? I'll take a look and see if I can spot the problem on the line mentioned.
DarylBeta Tester
file attached
On line 164 replace:
$this.resize_smaller
with:
$this->resize_smaller
It appears to be a typo in that file
We fixed that issue a long time ago, so you may want to re-install the latest version.
DarylBeta Tester
What is the best way to do that Ray?
I have the latest versions of all of the extensions, but this was built before them.
I think if you just applied the image resizer on any page of the site it would update the file. But you can just fix it manually. It shouldn't be an issue with sites you build in the future.
