choosing which repeating regions/template pages to display
Thread began 3/01/2017 10:43 am by Mags | Last modified 3/01/2017 3:20 pm by Ray Borduin | 902 views | 4 replies |
Mags
I have a PowerCMS repeating template region set up on a page and I want the client to be able to choose which of the repeating regions to make live and which to hide. In a normal recordset I would include a dB field called "Live" and set it to 0 or 1, then use a Show If command to display the item if Live = 1. I'm not sure how to amend the Show If field for a repeating template region though. I've added a text field to the template called Make Live and inserted the word YES, then added the following to my code but it's not working properly:
<?php if (WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'Surveys', 'Make Live', $row_rsSurveys['ContentPageSetOrder'] ) == "YES") { // Show if column... ?>
[repeating content here]
<?php } // Show if column... ?>
It seems like that would work. I'd have to debug it. If you give me a url and ftp access I'll debug to see what is going on.
Mags
Thanks Ray, details in PM.
This is the code that works:
<?php if (WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'Surveys', 'Make Live', true, $row_rsSurveys['ContentPageSetOrder'] ) === "YES") { // Show if column... ?>
You were missing the ",true" argument before the order. It keeps the cms from including all of the editable code so that you can do the string comparison directly.
Mags
Thanks Ray!
