html editor in a ajax powered bootstrap modal
Thread began 2/22/2017 12:49 am by mbunal | Last modified 2/22/2017 12:26 pm by Ray Borduin | 1297 views | 1 replies |
mbunal
how can i put html editor in a ajaxed bootstrap modal.
this is modal code:
<div class="modal fade" id="mdlSayfaYonetimi" tabindex="-1" role="dialog" aria-labelledby="mdlSayfaYonetimiLabel" aria-hidden="true">
<div class="modal-dialog modal-lg">
<form method="post" name="frmmdlSayfaYonetimi" role="form" action="">
<div class="modal-content">
<div class="modal-header">
<a aria-role="button" class="close" data-dismiss="modal" aria-hidden="true">&times;</a>
<h4 class="modal-title" id="mdlSayfaYonetimiLabel"></h4>
</div>
<div class="modal-body"></div>
<div class="modal-footer"></div>
</div>
</form>
</div>
</div>
this is ajax code:
$("#mdlSayfaYonetimi").on("show.bs.modal", function(e) {
var $modal = $(this);
$("#mdlSayfaYonetimi").modal('handleUpdate');
i = $(e.relatedTarget).attr("data-id");
k = $(e.relatedTarget).attr("data-komut");
$.ajax({
cache: false,
type: "POST",
url: "modalicerikyonetimi.php",
data: "i="+i+"&k="+k,
success: function(data)
var r = JSON.parse(data);
//alert(data);
$modal.find(".modal-body").html(r.govde);
$modal.find(".modal-title").html(r.etiket);
$modal.find(".modal-footer").html(r.butonlar);
It looks like you would have to manually initialize the ckeditor with javascript. So you would have to add a reference to the ckeditor.js file to the page, then add a <textarea> tag to your modal page with an ID you can use to reference it.
Then after loading the modal you can Use the CKEDITOR.replace('id') method to replace the existing <textarea> element with CKEditor.
