Weird things happening with special characters
Thread began 2/21/2017 2:48 pm by Mags | Last modified 2/24/2017 12:51 am by Ray Borduin | 701 views | 10 replies |
Mags
I know about encoding and displaying special characters, but I have something really weird happening! I have one CMS which governs several related client sites and some of the content is shared across these sites. All the sites use the same template and all have the same page encoding. I'm currently building another site for the same client using the same template with a few minor CSS changes, but for some reason if I input a special character via the CMS, say "£" it displays as "£" on this new site, but "£" on any of the other sites. However, if I input the £ sign directly into the database, it displays correctly on the new site but displays as � on the other sites. Any idea what might be causing this?
Sounds like a mismatch between one or more of these 3 things:
1) The <meta> tag charset
2) The database table defined charset for the pcms_contents table value field
3) The Connection/PowerCMS.php charset
Those three can be in conflict and it will cause issues like this.
Mags
I've double-checked everything and all charsets are fine - as I said, it's the same content from the same database on 8 different sites, all hosted on the same server, same page template, same page encoding but special characters don't display properly on just one of those sites. The top of all pages is as follows:
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
The pcms2_contents table default collation is utf8_bin and the ContentValue column is also utf8_bin.
There wasn't a charset declaration in the PowerCMSConnection.php file, however I added one as follows to see if it would make a difference but it hasn't:
mysql_set_charset('utf8',$PowerCMSConnection);
Odd. If you give me FTP access and steps to reproduce I can look into it further. I'd have to actively debug at this point.
Mags
That would be great Ray, details in PM section.
I'm going to need FTP access to all 3 sites to debug this. The working site, the broken site, and the cms site.
Mags
Apologies, FTP details for CMS site are in the PM.
I added the charset definition to all three site connection files:
That made them all consistent so you can use special characters.
Mags
Hi Ray
I thought that had fixed the problem, however it's thrown up a new set of issues that weren't there before! A lot of characters that were displaying correctly before are now displaying incorrectly on the live sites - example in PM below. Seems to be mostly apostrophes and dashes that are wrong.
They were out of sync before, so they probably show incorrectly in the cms as well now.
There is really no way to fix the problem without breaking it in some places that were encoded improperly in the first place.
At this point you will have to find and fix those pages improperly encoded in the past. The issue will be fixed moving forward I believe, and you can re-enter the improperly encoded characters now and they won't be an issue anymore.
I think now the character will show the same when entered through the CMS, through phpMyAdmin, and when displayed on either site. Until this update they would always be broken in one place or the other, but unfortunately any special characters entered in the past will still be incorrect in one or more location until re-entered now that the problem is fixed.
