My KFM editor was working fine, now it is stuck at the browse - webassist/kfm/?theme=webassist_v2
I looked up a previous ticket where you provided this solution
your page has references to jquery script files that do not exist on the server:
<script type="text/javascript" src="../ScriptLibrary/jquery-ui-core.min.js"></script>
<script type="text/javascript" src="../ScriptLibrary/jquery-ui-effects.min.js"></script>
you should upload those script files, i see a javscript error in the console, and i think the error is caused by those missing script files.
Can you please advise where is the ScriptLibrary located? also what is the easiest way to check for missing js files? Thank You!
