Not sending to e-mail address from Recordset?
Thread began 2/13/2017 2:29 am by Nathon Jones Web Design | Last modified 2/13/2017 11:16 am by Ray Borduin | 664 views | 1 replies |
I can't get an e-mail out on a registration confirmation form that uses the e-mail address from a recordset which is queried by the Save ID in Session behaviour created by the MySQLi insert behaviour on a previous page. Pages attached and links below. Thank you.
It looks like this would work.
Try adding this to line 19 of the details page:
var_dump($rsNEWUSER);
die($rsNEWUSER->getColumnVal("DCuserEMAIL"));
That should help you confirm that the recordset is returning the correct result. Once that is confirmed, then add this code below the email:
var_dump($_SESSION[$EmailRef."_From"]);
var_dump($_SESSION[$EmailRef."_To"]);
var_dump($_SESSION[$EmailRef."_Log"]);
die();
That should show you if it is trying to send the email and what it thinks the results are.
