gallery error
Hi, i have this error:
Warning: require_once(../webassist/framework/library.php): failed to open stream: Permission denied in /var/www/vhosts/31/169060/webspace/httpdocs/lapostboda.es/admin/admin_gallery/global.php on line 13 Fatal error: require_once(): Failed opening required '../webassist/framework/library.php' (include_path='.:/php/includes:/usr/share/pear:/usr/share/aps/php') in /var/www/vhosts/31/169060/webspace/httpdocs/lapostboda.es/admin/admin_gallery/global.php on line 13
It always work perfect, but today appear this error. Page http://lapostboda.es/admin/
an now this error too:
Deprecated: mysql_pconnect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /var/www/vhosts/31/169060/webspace/httpdocs/lapostboda.es/admin/Connections/powergallery.php on line 17 Warning: Cannot modify header information - headers already sent by (output started at /var/www/vhosts/31/169060/webspace/httpdocs/lapostboda.es/admin/Connections/powergallery.php:17) in /var/www/vhosts/31/169060/webspace/httpdocs/lapostboda.es/admin/admin_gallery/index.php on line 10
