Universal Email - adding in a reply-to header
Thread began 2/07/2017 9:33 pm by paulstock307210 | Last modified 2/07/2017 11:46 pm by Ray Borduin | 1012 views | 2 replies |
paulstock307210
Greetings, how does one set a reply-to address in Universal Email? I can see options for: to, from, cc, bcc in the UI but not reply-to address. I suspect that it can be done through the email headers manually (via adding in additional code to the page) but i thought i best check here first before i possibly break a working form. Thankyou in advance for the reply.
If you click on the "From..." button before the from field it will allow you to set the Reply-To from the interface that opens.
paulstock307210
Thank you for the swift reply. I just checked the UI on a new dummy form and it looks like that will indeed sort out the issue by allowing me to set the reply-to address through the UI.
I am unable to interact through the UI with the email settings on the main page for some reason (hence the new dummy form) but if worst comes to worst i can just remove all of the email code from the main page and re-do the email processing again using the UE UI (including setting the reply-to address) in order to get everything coded correctly (i trust your coding much more than mine haha).
Regadless you can consider this one resolved. Thanks again for the swift reply.
