Recordset Builder SQL builder won't input fields from DB
Thread began 2/06/2017 3:36 pm by jason363662 | Last modified 2/07/2017 2:30 pm by Ray Borduin | 101 views | 1 replies |
jason363662
The mysqli recordset builder connects to my local database, pulls up tables and fields, but the "Add to SQL" buttons don't work. I select the field I want and click Select, Where or Order By and nothing happens - the field doesn't appear in the SQL box.
If I use the Simple version it will build the SQL, but it would be more convenient to be able to build the query from the advanced window.
The same thing is happening if I try to use the deprecated query builder in DW.
Any input? I've cleared the DW Cache, reinstalled your extension with no luck.
Adobe broke that in the recent update. Try using the webassist "Query Builder" button above. It is a more visual way to build queries and can be used in place of that builder.
