MySQLi Check New Username and Server Validations on same page? Not possible?
Thread began 2/02/2017 8:26 pm by Nathon Jones Web Design | Last modified 2/03/2017 4:29 pm by Ray Borduin | 195 views | 6 replies |
I have a simple registration form on a page that asks for just a username (email) and password. I want to use the MySQLi Check New Username behaviour on this page to check against the username in case it's already registered.
However, I also want to run a server validation on the password field so that it contains between 8-16 characters and also so that it doesn't include spaces or certain characters.
Can I get this to work? Nope.
I can't set an action on the form because that cancels out the Check New Username behaviour. I can't set a "success" redirect page with the Check New Username behaviour, only a failure page. I have to direct to a separate page in order to get Server Validation to work.
My head hurts. What is the proper order in which I should do this?
Thank you.
NJ
You shouldn't need an action on the form. You can do both check username and server validation and the insert record on the current page. The only success redirect you need is the redirect after the insert takes place.
Set the failure redirect of the check username to the current page with a url parameter attached and then check for that url parameter to show a message that it failed.
That's what I have in place. It doesn't work.
If the Check New Username fails, a message is displayed because I have a url parameter attached to the failure redirect. However, if I try another username, that I know doesn't already exist, but the Server Validation fails this time, the Check New Username error message is still displayed.
I've even tried adding the same url parameter to the failure redirect of the Server Validation, but with a different value, but it just appends to the URL so that both parameters are true!
Urggh. What am I doing wrong (again!)? :( See attached and link below.
add a form action="dreamcaruk-register.php"
That will reset any url parameters after the form submits.
By default you don't need an action because it will default to the current page including all parameters. However want the url parameters cleared, so in your case you will want to add one.
Sorry Ray, I was following your advice to the word. That's resolved it now.
