MySQLiRecordset.htm applyServerBehaviour error - can't create or edit recordsets - have tried deleting WinCache
Thread began 1/30/2017 2:34 pm by Nathon Jones Web Design | Last modified 1/30/2017 3:59 pm by Ray Borduin | 1846 views | 5 replies |
Dreamweaver CC 2015.3
"While executing applyServerBehaviour in MySQLiRecordset.htm, a JavaScript error occurred."
Can't create or edit MySQLi recordsets. :(
NJ
Is this only on certain pages? Have you tried with a new blank page? If it only happens on a certain page I might be able to debug that page.
I removed the eCart behaviour and that seems to have solved it so have resolved to create my recordsets and then re-add the cart code once I'm ready.
I note that someone else was experiencing this, in the forum.
It will work, as a solution, for now. I'll come back to you if anything needs debugged or if I can't then get the eCart behaviour back on the page!
Thank you.
NJ
Are you using the latest version of eCart? The latest version of MySQLi? This sounds familiar to me and I think we fixed it a while ago.
MySQLi Server Behaviors
Current version: 1.0.4
eCart
Current version: 6.1.1
Are they up to date?
The version numbers are, but I've done some minor bug fix updates without incrementing version numbers so that I don't have to create a whole new .zxp.
It might make sense to reinstall the extensions if you haven't in a while and it may correct this issue.
