Connect to 2 different databases on the same page
Thread began 1/27/2017 11:03 am by Accumike | Last modified 2/01/2017 3:59 pm by Ray Borduin | 794 views | 6 replies |
Accumike
This is a bit complicated... I want to pull property information from another web site & database into my CRM system.
I can do this if I include two connections at the top of the page:
<?php require_once('../Connections/crm_realpress_wa.php'); ?>
<?php require_once('../Connections/realpress_property.php'); ?>
The first handles my crm data, the second my property data. No problem.
But I want to make the second db connection dynamic, so that the crm user can connect to different databases as required.
Using the old ADDT recordset extension, I have done this by making a db query at the top of the second connection and then passing the info into the actual connection parameters.
This is similar code for MySQLi:
<?php require_once('../webassist/mysqli/rsobj.php'); ?>
<?php // Get Connections to Property Database in RealPress site
$rsDBConnections = new WA_MySQLi_RS("rsDBConnections",$crm_realpress_wa,0);
$rsDBConnections->setQuery("SELECT id_dbc, idlic_dbc, domain_url_dbc, connection_name_dbc, hostname_dbc, database_dbc, username_dbc, password_dbc, iddbc_lic FROM cu_db_connection_dbc LEFT JOIN cs_licensee_lic ON id_dbc=iddbc_lic WHERE idlic_dbc = ? AND iddbc_lic IS NOT NULL");
$rsDBConnections->bindParam("i", "".$_SESSION['wa_user_licence'] ."", "-1"); //colname
$rsDBConnections->execute();
# FileName="WADYN_MYSQLI_CONN.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_realpress_dynamic_db = $rsDBConnections->getColumnVal("hostname_dbc");
$database_realpress_dynamic_db = $rsDBConnections->getColumnVal("database_dbc");
$username_realpress_dynamic_db = $rsDBConnections->getColumnVal("username_dbc");
$password_realpress_dynamic_db = $rsDBConnections->getColumnVal("password_dbc");
@session_start();
$realpress_dynamic_db = new mysqli($hostname_realpress_dynamic_db, $username_realpress_dynamic_db, $password_realpress_dynamic_db, $password_realpress_dynamic_db);
$realpress_dynamic_db->set_charset('utf8');
I then replace the connection 'realpress_property' with 'realpress_dynamic_db' and it should connect.
Howver, I have tried this using the code above, but it won't work - all I get is the actual SQL SELECT query showing on the page and nothing else.
Am I doing something wrong, or is this no longer possible with MySQLi?
All suggestions welcome, thanks.
It seems like this would work. I'd need FTP access and a URL to debug.
Accumike
Hi Ray, login / FTP details emailed to you.
I didn't get them. Please just add them to the private area of a reply on this thread.
Accumike
Details sent.
Your connection file had:
instead of:
$realpress_dynamic_db = new mysqli($hostname_realpress_dynamic_db, $username_realpress_dynamic_db, $password_realpress_dynamic_db, $database_realpress_dynamic_db);
(your password variable was repeated instead of having the database name)
Accumike
That's embarassing. Sorry about this, I looked at itmany times and still didn't see it!
Anyway, it works fine now.
Thanks for your help.
