How to add validation to select list in DataAssist form
Thread began 1/25/2017 2:07 pm by tmcbinc99963 | Last modified 1/30/2017 5:52 pm by Ray Borduin | 909 views | 12 replies |
tmcbinc99963
I've added a 'state' select list to a DataAssist Form Builder form, with Server Validation and Show if through the wizard, but it isn't validating.
I have another select list in an eCart page which has validation code for each 'state' entry. The new form doesn't have that and it doesn't seem to be added by the wizard.
Also looked at a WA tutorial, but it doesn't go into enough detail to pull it off.
I'm a bit confused. It looks like your State select list would always have a State selected. How would anyone not have a state selected so that the validation would fail? Do you have a sample URL I can look at?
tmcbinc99963
I've added a 'select a state' option. City or State select list now doesn't show up. I added display errors text on the local site, but doesn't show any errors.
Live view in PM.
Please attach a copy of the page and I can see what might be wrong.
tmcbinc99963
File attached.
Also, I need to create a 'careers' form with many of the same fields. Can I 'save as' this page to use, and would I need to copy all the included files also? Would it be easier to start from scratch with a new form in Form Builder?
You have put the validation show if server behavior around the entire select list. It should be placed around a message like "This field is required" placed after the select list.
tmcbinc99963
That's fixed, but get the following error on submit:
Warning: Cannot modify header information - headers already sent by (output started at /home/devadmin/public_html/test.primrose.com/ContactUs.php:4) in /home/devadmin/public_html/test.primrose.com/webassist/form_validations/wavt_scripts_php.php on line 85
You have a blank line of code on the top of the page between the php tags. You need to remove that and the error should go away.
tmcbinc99963
On submit, the form now reverts back to the same page, with a Name validation error, like I haven't entered a name, though the name is there.
Your identifiers in your server behavior are set to "1" for city and state validation as well as first name. They should match the identifiers in the show if validation for those fields which are "6" and "7". You must have copied and pasted to add those rows.
Another mistake that you made is that you are validating the field "State" but the field name is "SelectState". That is the validation that is actually failing.
