Dreamveawer CS6 : MySQLi Server Behaviors installed but dont show
I have installed the behaviors, but I cannot find them in DW CS6 - what to do?
I also have DW CC 17 - when am I going to be able to use the behaviors in that?
Did you install the free Server Behaviors and Database extension from the Adobe Store?
MySQLi Server Behaviors are available from the Server Behaviors window with a .php page open that is saved to a configured site in Dreamweaver.
In DW C6Deleted the file under configuration - reinstalled and it works :)
How about instlling in CC 17?
It should work the same way for the most part with two considerations:
1) You have to install Server Behaviors and Database connectivity as a separate extension from the adobe store (free);
2) You have to use the command line, or a third party extension manager like: https://www.dmxzone.com/go/22670/dmxzone-extension-manager-for-dreamweaver/ to install the extension (also free)
