populated form with recordset then updates, but redirect after update not working
Thread began 1/18/2017 7:56 am by anonymous | Last modified 1/18/2017 9:41 am by Ray Borduin | 572 views | 1 replies |
anonymous
I have a detail page that passes an id to this update page. The form is populated by the recordset. Then update is done on submit, which updates the database. Then the redirect fails and populates the form again with the recordset.
No spaces, no action... I made it work on another page, then this one fails and I can't see it. :(
Thank you in advance!
updateAthlete.php
The code you added to line 6:
echo "This is the athletes ID " . $idAth;
That will prevent the redirect since you can't redirect after writing to the page.
