Do you have an install tool to install the extension on Dreamweaver CC
Thread began 1/16/2017 8:45 am by sandhills404774 | Last modified 1/16/2017 11:39 am by Ray Borduin | 335 views | 1 replies |
sandhills404774
Hello there,
I have a few "older" WebAssist" extensions that worked with Dreamweaver 6, but do not work with Dreamweaver CC. I understand Adobe removed the extension manager, so I wonder if WebAssist has a work-around to address this challenge?
Thanks, Cheers, Doug
There are two options. You can use the free extension manager from DMXZone: https://www.dmxzone.com/go/22670/dmxzone-extension-manager-for-dreamweaver/
The second option is to install the extensions using the command line as outlined here: https://helpx.adobe.com/extension-manager/using/command-line.html
