My form required pop up bubbles are in the background. Where is the css to move to foreground?
Thread began 1/09/2017 3:07 pm by lr_leal239405 | Last modified 1/10/2017 3:34 pm by Ray Borduin | 1064 views | 3 replies |
lr_leal239405
My form 'required' pop up bubbles are in the background. Where is the css to move to foreground? I can't get it to come forward. 1-800Collision.com/index.php (scroll to bottom)
Open the css file: /jq_validation/Bloom.css
Add a z-index to the .Bloom-wrapper class on line 54 like this:
z-index: 99999;
That should put the errors above the floating window. It looks like you may still have a positioning problem. Have you adjusted the css by hand already in that file?
I think the easiest fix will be to remove the margin-left in the .Bloom style on line 23... either that or else add the same left margin to .Bloom-before (line 61) and .Bloom-after (line 71).
lr_leal239405
Thanks. I really appreciate it. The wrapper did it. The margin is something I had entered and it's working for this form. Also...question, are the php validations needed any longer? it seems to be using the html css form validations.
Hypothetically a hacker could turn off java-script and use an older browser to get by the validations and php are foolproof. But realistically why would someone purposefully hack your page just to leave fields blank, so on this page server validations aren't necessary. There might be some circumstances where server validation is still relevant to prevent hacking.
