Help with CURL to send emails
Thread began 1/06/2017 10:47 am by iain331081 | Last modified 1/10/2017 11:28 am by Ray Borduin | 883 views | 2 replies |
iain331081
Hi Ray - hope you had a good Christmas and New Year.
You helped out a few months ago with setting up an array to generate an email list using CURL.
I have just been using it on another page, but can't seem to get it working here - its not sending any emails. I have attached the pages here - if you could have a quick look and see if you could spot anything that would be a great help.
I don't see any obvious problems. I'd probably have to debug it.
To do that I'd probably
1) set the CURLOPT_RETURNTRANSFER value to true
2) increase the CURLOPT_TIMEOUT value to 60
3) set the execute value to a variable and dump it to the page like:
$curlReturn = curl_exec($ch);
var_dump($curlReturn);
die();
4) on the send email page, write the query to the page by removing the comments in front of line 39
That should give you the query used to return the results. Try executing it in php MyAdmin directly and see if it returns the results you expect. I suspect it may shed some light on where the problem is, but you would work from there to figure out the actual problem.
I could help with this in a premier support ticket.
iain331081
Thanks Ray - I'll have a look at this and get back to you. I also need to remind myself if there was some domain specific permission granted on the Amazon SES thing that the emails are routing through.
