Templates/ being added to PowerCMS telephone link
Thread began 1/02/2017 2:37 pm by Jason | Last modified 1/13/2017 1:32 pm by Ray Borduin | 1653 views | 10 replies |
Jason
I have a region in my PowerCMS that contains this source code (I've verified this in the editor using the source option and in the database itself, and it's definitely what's there): <a href="tel:6183518463"> | 618.351.(VINE) 8463</a>
But, when it displays on my website it's<a href="Templates/tel:6183518463"> | 618.351.(VINE) 8463</a>
Any idea why it's adding Templates/?
That looks like a bug in framework builder. You must be using a theme or plugin and and it is trying to update your path.
To fix this open up the file: webassist/framework/framework.php and find this line:
$ignore = '/^(https?:\/\/|mailto:|javascript:|#|\/)/i';
and replace it with:
$ignore = '/^(https?:\/\/|mailto:|javascript:|tel:|#|\/)/i';
Jason
Thanks for the quick response!
My current line looks like this:
$ignore = '/^(https?%3A%2F%2F|https?:\/\/|mailto:|javascript:|#|\/)/i';
Should I add leave the extra stuff and add the tel, or just copy what you sent me?
just add the tel. I have a local version that might be older that I used as a reference:
$ignore = '/^(https?%3A%2F%2F|https?:\/\/|mailto:|javascript:|tel:|#|\/)/i';
Jason
Awesome. Thanks Ray!
Jason
Framework Builder overwriting changes
Anytime I use the framework builder now it changes the new line
back to the old line
I've managed to catch it everytime so far, but I know I'll forget eventually and end up back in the same spot I started. Is there anyway to prevent it from overwriting the changes?
You can update it in your Dreamweaver configuration folder. Just navigate to your User configuration folder for Dreamweaver and find the file: Shared/WebAssist/Framework/Includes/framework.php
Updating it there will update the version used when applying on future sites as well.
Jason
I can't seem to find that folder Ray. I'm looking in C:\Program Files\Adobe\Adobe Dreamweaver CC 2017\configuration\Shared, but that's as far as I got before I lost the trail. There's no webassist folder in there. I'm showing hidden files and folders, but still no luck. Am I looking in the right place? I also tried searching C:\Program Files\Adobe\Adobe Dreamweaver CC 2017\ for framework.php, but I didn't get any results. I'm running the latest version of DW on Windows 10.
Jason
Nevermind! I forgot about using %appdata%. I got it. Thanks Ray!
That is the wrong configuration folder.
Open up windows explorer and type in: %appdata% as the path.
That will take you to the correct root where you can drill down to the dreamweaver configuration folder where the file resides. It will be something like: C:\Users\jason\AppData\Roaming\Adobe\Dreamweaver CC 2017\en_US\Configuration
