map not showing
Thread began 12/22/2016 6:10 am by Jamie | Last modified 12/26/2016 7:53 pm by Ray Borduin | 941 views | 8 replies |
Jamie
map not showing
Hey Ray
On this page http://www.ybg.org.uk/member/ice-maiden-cakes, I cant seem to find what is conflicting and stopping the location map from showing in this position: http://prntscr.com/dmk63f
I know that the map scripts are working as its fine as an individual instance on the contact page.
Cheers
Jamie
It appears this map is named map_2... but in your include file: webassist/google_javascript/wagmp_maps.js
That only has a map_1 reference. It appears they may be out of sync.
Maybe manually update the js file and change the map_1 references to map_2 and see if that fixes it.
Jamie
thanks but that hasnt fixed it.
I have done a test page with just a map added to it and it isnt showing the map either: http://www.ybg.org.uk/test2.php
This test page has map_5, but your .js file still has map_1.
Update: view-source:http://www.ybg.org.uk/webassist/google_javascript/wagmp_maps.js
and add references for maps 2-5 by copy/pasting the line for map1.
Jamie
I dont know why it isnt showing for you but they are definitely there: http://prntscr.com/dn6rfj
Can I get access to the google account where you got the api key? It looks like google may have updated their requirements and it may need some additional configuration options I'd like to debug.
Jamie
Sure thing. See PM
It looks like google changed their requirements. Now you need to go in and specifically grant access to the maps.geocode service associated with the key you are using. Please try that and see if it fixes the problem.
Jamie
thats worked many thanks Ray
