Is it possible to use the dependent Country / State drop downs created by eCart in a seperate registration form?
...so that what a person uses to register matches what needs to be entered at checkout stage?
Thank you.
NJ
Thank you.
NJ
It is possible, but would require some custom coding. You could probably use some of the same AJAX code but would have to strip it out of the eCart javascript and add it to the page you were using it on.
This is something I could help with in a premier support ticket.
