Myslqi Server Behaviors
Good afternoon,
I would like to ask if Mysqli Server Behaviors is compatible with Dreamweaver CC 2017. Is that I found it interesting to buy but I do not know if it is compatible or not.
Thank you
Jorge Prado Braz.
Good afternoon,
Thank you
Jorge Prado Braz.
Yes it is. You just have to install the free Database and Server Behaviors extension as well.
I am running Dreamweaver CC 2017 and have successfully installed and activated MySQLi Behaviors. I see the Web Assist -> DataBase-> Model Database as a menu option, and it looks like it create mySQLI versions of the databases that I had with the old DreamWeaver extensions, so I can successfully model the database.
However, I am not seeing any menu options for Database or Server Behaviors.
How do enable/download and install these??
You can download the "Database and Server Behaviors" extension available free from the Adobe store. (from Dreamweaver go to Window->Extensions->Browse Extensions...)
Once it is installed you can access the Server Behaviors panel and see the remaining functionality available.
Ray,
I'm running MySql 5.5 and PHP 5.4, with Dreamweaver cc 2017. Will MySQLi work with my setup? Do I need to do anything to the MySql database or PHP version?
That should be fully compatible.
