Can't add a rule to compare my db field
Thread began 12/14/2016 8:10 pm by lr_leal239405 | Last modified 3/06/2017 10:42 am by Ray Borduin | 2047 views | 6 replies |
lr_leal239405
I can't add a new rule or edit one that secures the page by checking if user is checked as 'Admin' in my db. Yes, I do have the fields in my db, but when I try to edit a rule I added and trying to read db I'm getting "The files from the _mmServerScripts folder are for the server model PHP-MySQL. You try to connect to a database using a different server model .
Please remove this folder outside the Dreamweaver environment on both local and testing machines and try again.
I did it not too long ago and didn't have problems by comparing to another field. It's been working fine, but now I don't know what I did or why I'm getting this message. Please help.
This is usually an issue with the Server URL specified in the Dreamweaver site definition for the server specified as the "testing server".
If you can't find the problem you could export your site and send me the dreamweaver .ste file and I could import it and see if I can spot the issue.
lr_leal239405
I have never resolved this issue. To reiterate, I have a column named 'Administrator'. I need only those checked as Yes (or 1) in the db column 'Adminstrator' to be able to access the Insert, Update, etc. files in my admin folder. I sent you an ftp for this in private msg.
Please export your site definition and send me the dreamweaver .ste file so I can import it and see if I can spot the issue.
lr_leal239405
attached is the doc. thanks.
Your site is set up to automatically redirect to https:// but your Web URL setting in your site definition only has http://.
If you update the testing server to use https:// it should fix your problem.
lr_leal239405
thanks. that was it.
