HTTPS User Athentication
Thread began 11/29/2016 10:47 am by LionsMane | Last modified 11/29/2016 2:25 pm by Ray Borduin | 915 views | 3 replies |
LionsMane
I have a site that needs to pass PCI compliance, and the last hurdle is that the WA User Authentication behavior is being noticed as passing login information via HTTP, and we need it to be HTTPS. What changes can I make in the code to make this happen?
Just change any links into the login page to use https:// at the front.
LionsMane
links..
Yes, so any links on the page are already https, but the PCI scan specifically calls out the "authentication" process and how it passes values. So, are you saying that all I need to do is modify this line: $SuccessRedirect = "blah.php"; to be $SuccessRedirect = "https://www.domain.com/blah.php"; instead?
Yes that is correct.
