Modifying Wizard search parameters and detail page links for products that have more than one product type
Thread began 11/21/2016 12:37 pm by tmcbinc99963 | Last modified 11/22/2016 2:50 pm by Ray Borduin | 1630 views | 8 replies |
tmcbinc99963
I've created a DataAssist product search, to search by product number and product type. It works as it should if each product has a unique product type. However, some products have multiple product types. For example, a search for product 252 should have a result of 252 Torque and 252 Tractor.
A separate Db table using foreign keys for both product and product type works properly on a dynamic tab panel in the site, but not on the DataAssist results and Detail pages:
A search for '252' returns only 252 Torque, rather than 252 Torque and 252 Tractor.
A search for 'Torque' lists 252 Torque; a search for 'Tractor' lists 252 Tractor, which is correct.
When clicking the 252 Torque detail link it goes to 252 Torque. When clicking the 252 Tractor detail link it goes to 252 Torque, rather than 252 Tractor.
The recordsets all have INNER JOINs to combine the appropriate tables in addition to the separate product and product type table mentioned above.
Tried reconfiguring the search and also using AND in the Wizard, but still doesn't work properly.
On a related note, the tab panel that uses the FK table also returns 252 Torque regardless of which product is chosen.
Files attached.
I added a group_concat() to your SQL statement to return multiple categories when applicable.
tmcbinc99963
252 Torque and 252 Tractor should appear in the results as two different listings, each with their own unique link to the detail page.
In the tab panel, clicking the 252 link (under the Torque tab) should show the 252 Torque product on the detail page (works properly). Clicking the 252 Tractor link (under the Tractor tab) should show the 252 Tractor product on the detail page (still shows 252 Torque).
(252 is just one example. There are four other products that have multiple product types; possibly more upcoming)
What are the two product ID's for the 252 torque and 252 tractor products? They will need different IDs to have separate links to the detail page.
tmcbinc99963
Product number 252 has an ID of 26 in the 'prod' Db. This ID is used as a foreign key in the 'prodtype' table (column ProdIDType).
The product types originate in the 'lubetype' table as LubeTypeID 4 (torque) and 9 (tractor). These are used as foreign keys in the 'prodtype' table (column LubeID).
The primary key in the 'prodtype' table (column ProdTypeID) for each is 29 and 30
I've tried using the 'prodtype' table, both as a data source in the WADAProd recordset and in updating the Wizard parameters. Neither provided the desired result.
Your SQL statement has GROUP BY ProductID. That will only show one row for each unique product ID. If you change it to GROUP BY ProductID, LubeTypeID, that will show unique rows when either field is unique.
tmcbinc99963
The results now show a separate result for each product, which is correct.
The pencil link to the detail page still goes to 252 Torque when 252 Tractor is clicked.
Tried adding ProdIDType to SQL 'GROUP'; plus changing parameter to other Db columns - ProdIDType, LubeID, LubeTypeID.
It shows the expected number in the URL, but returns 'record has been removed'.
You would have to pass both the product ID and lube type ID to the other page in order for it to know which version to display.
I've made the necessary changes so you can see what I mean.
tmcbinc99963
Works perfectly. Thanks Ray.
