password user protected login page working perfectly localhost working remote server loading database recordset next page Please advice regards Dr R Dasgupta
Thread began 11/21/2016 9:19 am by Ramaprasad | Last modified 11/21/2016 2:45 pm by Ray Borduin | 720 views | 1 replies |
Ramaprasad
connection:
# FileName="WADYN_MYSQLI_CONN.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_conn_members = "localhost";
$database_conn_members = "cnmcuk_cnmc";
$username_conn_members = "users";
$password_conn_members = "daktarbabu";
@session_start();
$foundConnection = false;
if ($foundConnection == false) {
$domains = explode(",","daghraphics.co.uk");
for ($domindex = 0; $domindex<sizeof($domains) && !$foundConnection; $domindex++) {
$domainCheck = trim($domains[$domindex]);
if (strpos(strtolower($_SERVER["SERVER_NAME"]),strtolower($domainCheck)) !== false && ($domainCheck == "" || strpos(strtolower($_SERVER["SERVER_NAME"]),strtolower($domainCheck)) == strlen($_SERVER["SERVER_NAME"])-strlen($domainCheck))) {
$hostname_conn_members = "ftp.cnmcuk.com";
$username_conn_members = "cnmcuk";
$password_conn_members = "Dasgupta21!";
$foundConnection = true;
$conn_members = new mysqli($hostname_conn_members, $username_conn_members, $password_conn_members, $database_conn_members);
login
<?php require_once('../Connections/conn_members.php'); ?>
<?php require_once('../webassist/mysqli/authentication.php'); ?>
if (isset($_POST["submit"]) || isset($_POST["submit_x"])) {
$Authenticate = new WA_MySQLi_Auth($conn_members);
$Authenticate->Action = "authenticate";
$Authenticate->Name = "user";
$Authenticate->Table = "userpass";
$Authenticate->addFilter("user", "=", "s", "".((isset($_POST["user"]))?$_POST["user"]:"") ."");
$Authenticate->addFilter("password", "=", "s", "".((isset($_POST["password"]))?$_POST["password"]:"") ."");
$Authenticate->AutoReturn = false;
$SuccessRedirect = "friend.php";
$FailedRedirect = "denied.php";
if (function_exists("rel2abs")) $SuccessRedirect = $SuccessRedirect?rel2abs($SuccessRedirect,dirname(__FILE__)):"";
if (function_exists("rel2abs")) $FailedRedirect = $FailedRedirect?rel2abs($FailedRedirect,dirname(__FILE__)):"";
$Authenticate->SuccessRedirect = $SuccessRedirect;
$Authenticate->FailRedirect = $FailedRedirect;
$Authenticate->execute();
I am attaching the codes. I don't see any fault. But will not load the next (friend) page.
If it works locally and not on the live server then it isn't a problem with the code you provided. It may be a server configuration issue or just different values in the live database preventing login.
I'd need FTP access to debug completely and identify the problem.
