using a session variable on another page
Thread began 11/16/2016 9:20 am by Jamie | Last modified 11/17/2016 12:37 am by Ray Borduin | 230 views | 2 replies |
Jamie
Hey Ray
Have created a session
@session_start();
if(!isset($_SESSION["UseEmail"])) {
$_SESSION["UseEmail"] = "".$row_WADAlogins['UserEmail'] ."";
on the attached page (customer_update.php) so that I can use the email address on the other atatched page message_insert.php
When I try to echo the session to the message_insert.php page it shows nothing.
What have I done wrong?
Cheers
Jamie
The code is in the wrong order. Since you are setting the session variable to the value from the recordset, it needs to be below the recordset on the page. Just move the code down below the recordset on the customer_update page and it should fix the problem.
Jamie
perfect. thanks
