couple of 'on state' problems
Thread began 11/14/2016 9:05 am by Jamie | Last modified 11/14/2016 3:50 pm by Ray Borduin | 828 views | 4 replies |
Jamie
Hey Ray
I have a couple of issues which I am struggling to overcome. One is a set of breadcrumbs and one is an on state for a sidenavigation
If you go to seasons both are working fine.
If you then click on the main image (Spring) you'll see that I lose the on state in the left hand navigationand also the side nav isnt showing the on state (as it does in the top level). http://prntscr.com/d77gl5
The same is on the subsequent product detail page.
Cheers
Jamie
I'm not following... I looked at the page but the issue didn't stand out to me and it appeared to be working correctly. I'm sure I'm missing something or I'm seeing a different result than you are.
Jamie
Sorry. If you look at the attached image, the top level shows how the on state should be on the side navigation - no opacity.
In that same image are then the categories and then product which you can see that, although they shoudld have an 'active' state as they do in the top level they dont and have opacity
It looks like your $CategoryNav recordset isn't using the correct SQL statement.
You have a reference to the column "parentpermalink" in your if statement determining when to add the opacity, but that column doesn't exist in your recordset.
Jamie
Ok. Thanks
