opt in email verification - keeps saying link expired
Thread began 11/10/2016 11:41 am by russell298997 | Last modified 1/05/2017 11:16 am by Ray Borduin | 1256 views | 9 replies |
russell298997
Hi, ploughing thru this double opt-in registration (really thoro tutorial - excellent- thanks!) and running it live, i register ok, i get the email verification link ok, but when i click the link and go to
http://www.fhcsolution.co.uk/user-confirm.php?id=2&randomstring=5ino7d&email=russell@severndesign.co.uk
i get the message:
Your verification link has expired. Visit your profile page to send a new link.
dont understand why it doesnt verify. so far as i can see it has the three variables it should be passing and the email address is correct - probably my bad somehwere i'm sure - any ideas?
thanks in advance guys and keep up up the fab work
WAfiles.zip
The code looks correct to me on the confirm page. Is the random string stored correctly in the database? If you gave me FTP access I could go through the process and debug it along the way to figure out what is wrong.
I see that your code on lines 40-41 refers to: randomString, but the url parameter in the url is: randomstring. The capitol 'S' will make a difference. Try changing that in the emailed url and that should fix the problem.
russell298997
see PM
Somehow your recordset is out of sync. It had on line 39 the parameter defined: $paramrandomstring_rsVerify
But then in the recordset it was referred to as: $paramrandomString_rsVerify
The case sensitivity. It probably didn't update properly when you tried to change it.
The resend confirmation link worked for me from the update page, so I'm not sure what the issue was with that, but it appears to be resolved.
russell298997
Thanks. Whatever happened it worked for me now so grateful for your intervention. When I did subsequently log in I thought I'd told it to take me to questionnaire.php but it took me to the login page again saying I WAS logged in. Presumably that's just a tweak somewhere to the 'if successful' redirect. If you know offhand where I need to tweak that it'd be handy but otherwise I'll take a trawl thru.
Thanks as ever Ray
The login redirect is a setting in the login server behavior. Changing it won't cause any issues.
russell298997
Hi Ray - quickie - i got the same problem as above with paramrandomString problem i think - may bne due to me making small update to userconfirm page and overwriting what you changed i think - i'm just not sure whether i should be changing the instance on line 39 to lower case or vice versa - i presume its the code here from 39-52 that needs to be in sync
$paramrandomstring_rsVerify = "1";
if (isset($_GET['randomstring'])) {
$paramrandomstring_rsVerify = $_GET['randomstring'];
$paramemail_rsVerify = "1";
if (isset($_GET['email'])) {
$paramemail_rsVerify = $_GET['email'];
mysql_select_db($database_fhcdbase, $fhcdbase);
$query_rsVerify = sprintf("SELECT * FROM users WHERE UserID = %s AND users.randomString = %s AND users.UserEmail = %s AND users.randomString <> '0'", GetSQLValueString($colname_rsVerify, "int"),GetSQLValueString($paramrandomString_rsVerify, "text"),GetSQLValueString($paramemail_rsVerify, "text"));
$rsVerify = mysql_query($query_rsVerify, $fhcdbase) or die(mysql_error());
$row_rsVerify = mysql_fetch_assoc($rsVerify);
$totalRows_rsVerify = mysql_num_rows($rsVerify);?>
which lines do i change?!
should be:
GetSQLValueString($paramrandomstring_rsVerify, "text")
russell298997
Got it! Thanks Ray
