Deprecated: mysql_pconnect(): The mysql extension is deprecated and will be removed in the future: use sysqli or PDO instead
Thread began 10/31/2016 9:34 am by ron.haysbert231945 | Last modified 11/03/2016 11:37 am by Ray Borduin | 3966 views | 7 replies |
ron.haysbert231945
I have attached the two files with the error message.
I could not locate the area in the ini file that controls the deprecated items.
T
php.ini.log
You have:
error_reporting = E_ALL
Update it to:
error_reporting = E_ALL & ~E_DEPRECATED & ~E_STRICT
ron.haysbert231945
SQLI
Made the changes in the PHP.INI file (attached) error still there. Can you make the changes and sent me the file.
php.ini
Create a blank page on your web site with this code:
phpinfo();
There are often more than one php.ini files and you may be editing the wrong one. That will tell you the location of the one that is actually being used.
ron.haysbert231945
php.ini
I traced the php.ini file and I attached it for you to see. there are 0 bytes.
Are you updating the php.ini file in that location?
C:/wamp/bin/apache/apached2.4.23/bin/php.ini
The .ini file looks correct, so my best guess is that you are updating the wrong file?
ron.haysbert231945
thanks again for the help. Are you familiar with a ".symlink" file. This is where my php.ini is being pulled from. I can't located it..I have attached a image.
The phpinfo() says the php.ini file is being pulled from:
Have you tried updating it there?
