Is Ecart Check out wizard form not responsive?
I ran the wizard and none of the forms are responsive
The forms themselves aren't responsive, but you can easily update them to make them responsive with a few media queries. If you give me a url where I can see the design I can suggest what to do.
Am still in early development on localhost mamp am using bootstrap for my design so would like all forms to match with that
Let me know when you have a live page I can look at and I can help.
I have a checkout page I created with ecart6 checkout wizard, I customized the customer info form using bootstrap. Everything seems in order however the form does not hide it self once completed.
Do you have a url where I can test? I'll take a look and see if I can spot the problem. I may need FTP access to play around with the code.
The ftp info is attached
I can't seem to add anything into the cart. What page should I go to? Maybe you are working on it now?
I get an error after filling in that form so I'm unable to add to cart.
