Quantity no longer works in shopping cart
Thread began 10/27/2016 7:37 pm by phil107723 | Last modified 11/02/2016 2:21 pm by Ray Borduin | 566 views | 5 replies |
phil107723
The quantity field on shopping cart is no longer working. I don't know how long it has been broken . I noticed it when I was updating something else.
It doesn't matter if I change the quantity on the product page or try and update it in the shop cart.
I have recently added a second shipping rule and another option ( BafflePrice) to the cart calculations. Here is a link to a product on the website http://www.adrenalinr.com/productdetail.php?productID=524 and I have attached the shopping cart code for the product page, shopping cart page and the ecart1_PHP.php
I can't see anything wrong. As always your help is appreciated.
Phil
phil107723
Just to clarify. When you input that you want 2 of a product only 1 product is added to the shopping cart.
I just tested and it appears to work for me. What browser are you using? What are you selecting from the lists? I can't seem to reproduce the issue you are reporting.
phil107723
Hi Ray thanks for your help. It is happening on all products. I've attached 2 screenshots of what's happening. I'm using Firefox 49.0.2 but I've tested it on an ipad with safari and that has the same issue.
Phil
It looks like you have misplaced parenthesis in your cart object.
Open your shopping cart definition and go to the "Calculations" tab. Select the TotalPrice calculation.
You have it set to:
([Price]+[SizePriceInc]+[InletPriceInc])+[BafflePriceInc] * [Quantity]
but it should be:
([Price]+[SizePriceInc]+[InletPriceInc]+[BafflePriceInc]) * [Quantity]
phil107723
Yes that's it thanks Ray. I must have accidentally left it in it's original position when adding the BafflePriceInc. .
