Changes made in Data Model sometimes don't take all the time - maybe the the .xml file created/updated gets corrupt?
I've had to delete connectionname.xml data model file a few times and recreate it. I'm on Windows 10, use DW CC and XAMPP. Problems seems to happen when I: 1) use an extended monitor to work on the model, 2) move tables around 3) create MySQLi recordsets 4) make changes to the model. Can you suggest what is going on? Are there any known bugs? When it works it is great. But I am spending a lot of time recreating things. Also,. how are table-table connections deleted in Data Model? I deleted the table with the connection to be removed, then put it back in, seemed to be the only way to do it
