How can I use two parameters for a URL?
Thread began 10/19/2016 9:34 pm by mrs | Last modified 10/24/2016 2:54 pm by Ray Borduin | 915 views | 4 replies |
mrs
I have set a link like so:
<a href="blog.php?id=<?php echo $row_rs_blog['blog_id']; ?>-<?php echo $row_rs_blog['blog_url']; ?>">
So, in the address bar it will look like this:
http://website.com/blog.php?=1-this_is_my_record_title
Is it possible to pass two variables into a recordset, and if so, how do I set the SELECT so I am using two variables? Currently I am getting: 'Query was empty'.
This is how I have set my recordset on the detail page, but obviously something is wrong:
$colname_rs_blog = "-1";
if (isset($_GET['id'])) {
$colname_rs_blog = $_GET['id'];
mysql_select_db($database_PowerCMSConnection, $PowerCMSConnection);
$query_rs_blog = sprintf("SELECT * FROM tbl_blog WHERE blog_id = %s AND blog_url = %s", GetSQLValueString($colname_rs_blog, "text"));
$rs_blog = mysql_query($query_rs_blog, $PowerCMSConnection) or die(mysql_error());
$row_rs_blog = mysql_fetch_assoc($rs_blog);
$totalRows_rs_blog = mysql_num_rows($rs_blog);
mrs
Just having a play and came up with this recordset but it's still not working, however the page is not just erroring now. no record is being printed, but it is showing the page template now. Before I was just getting Query was empty. Here's my RS code:
$urlTitle_rs_blog = "-1";
if (isset($_GET['title'])) {
$urlTitle_rs_blog = $_GET['title'];
$query_rs_blog = sprintf("SELECT * FROM tbl_blog WHERE blog_id = '".$colname_rs_blog."' AND blog_url = '".$urlTitle_rs_blog."'", GetSQLValueString($colname_rs_blog, "text"),GetSQLValueString($urlTitle_rs_blog, "text"));
And tried this as a URL:
<a href="blog.php?id=<?php echo $row_rs_blog['blog_id']; ?>-?title=<?php echo $row_rs_blog['blog_url']; ?>">
This is the result in the address bar:
website.com/blog.php?id=2-?title=cycling-tour-lejog-real-life-training
But, when I echo both $colname_rs_blog and $urlTitle_rs_blog to see what values are populating the variables, I am getting this:
-12-?title=cycling-tour-lejog-real-life-training. For some reason it has -1 in front of the id.
I actually think colname_rs_blog is defaulting to -1 and the record id is somehow tagging on to urlTitle_rs_blog when I echo the params, but why I don't know!
Any thoughts?
You should separate multiple parameters with &, so it would be:
<a href="blog.php?id=<?php echo $row_rs_blog['blog_id']; ?>-&title=<?php echo $row_rs_blog['blog_url']; ?>">
The recordset you created has a SQL injection vulnerability. It should be:
$query_rs_blog = sprintf("SELECT * FROM tbl_blog WHERE blog_id = %s AND blog_url = %s", GetSQLValueString($colname_rs_blog, "text"),GetSQLValueString($urlTitle_rs_blog, "text"));
mrs
Ooo... are you saying that my way of grabbing a parameter value is the vulnerability?
I.e.: blog_id = '".$colname_rs_blog."' AND blog_url = '".$urlTitle_rs_blog."'
AND, is this the case even if I am only doing a select? I am not doing an insert on this page.
Would that also apply if I did this?:
$b_url = $row_rs_blog['blog_url'];
$b_id = $row_rs_blog['blog_url'];
and then did this with the select:
blog_id = '".$b_url."' AND blog_url = '".$b_id."'
You are bypassing the GetSQLValueString() function and referencing a posted form value directly. That is the vulnerability. Any time you directly reference a value that is submitted in a form or passed through a url without scrubbing it, there is a potential exploit.
