plugin delete not working
Thread began 10/17/2016 3:34 pm by Jamie | Last modified 10/18/2016 1:09 pm by Ray Borduin | 872 views | 6 replies |
Jamie
have the attached customer_update page which has got a plugin using message_results
if I delete an item in the message_results plugin,
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'ORDER BY MessageDate DESC LIMIT 0, 50' at line 1
I am pretty sure its to do with this within the select statement
WHERE MessageUserID = {$_SESSION['UserID']}
but I need that to display the messages that are associated with that user...
What am I doing wrong please?
Cheers
Jamie
"SELECT * FROM messages WHERE MessageUserID = " . $_SESSION['UserID'] . " ORDER BY MessageDate DESC";
Jamie
thanks but still getting
Are you sure the session variable is set?
Try writing your SQL statement to the page before the line with mysql_query( (afterline 65) add:
die($query_limit_WADAmessages);
See if you can spot the problem with your SQL statement.
Jamie
ok, its returning SELECT * FROM messages WHERE MessageUserID = ORDER BY MessageDate DESC LIMIT 0, 50
so clearly UserID is not being set on the plugin although whne I was echoing the session to make sure it was showing the right user it worked ok
am assuming then that it has to do with the delete function but not sure what I need to do to get it set...
Is the session variable being reset? I see your set session code is:
if ("" == "") {
$_SESSION["UserID"] = "".($_GET['UserID']) ."";
That means that if you visit that page without the url parameter it will be reset to blank.
Perhaps it should be:
if (isset(($_GET['UserID']))) {
Jamie
thats done it. Thanks Ray
