eCart checkout 'continue ' button not working
Looked in the forums but didn't see a solution. eCart checkout.php page 'continue' button doesn't redirect as it should.
File attached.
File attached.
You had a bunch of mismatched html and <div> tags with no closing </div> tags on your confirm_cart.php page That was causing the code below to not display properly.
I added the closing </div> tags and that seems to have fixed it.
